We are having a lot of issues on our machine just doing what should be a simple task - surfacing the spoil board. I initially tried a 2d Face tool path, but couldn't get that to work as it kept triggering the limit switched on my machine, no matter what I tried to do. So instead I switched to a 2d pocket tool path, that removes 0.02 off of the surface. The problem is, it leaves about a 0.2'' line of material on the entire surface and edges, So I end up having to move the zero position over and run the same thing 3 or 4 times to get a somewhat useable spoil board (you can see the line in the photo) Having to do this on both sides of the spoil board is very time consuming and removes way too much material from the spoilboard to make this feasible. Any guidance someone could give would be very much appreciated. The f3d file will be attached.
