Help with Sketch Trim command
SGoldthwaite
Message 1 of 13
SGoldthwaite
I can't trim the sketch lines I want.  When I hover over lines in my sketch, some turn red, but not the ones I want.  See screencast:
http://autode.sk/1M3f0Vw
I also attached my Fusion file.
Replies (12)
Message 2 of 13
HughesTooling
I think it's because they are part of a rectangular pattern, I guess you're not allowed to edit a line if it's part of an array. There doesn't seem to be any way to extract the lines from array either.
Mark.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 13
SGoldthwaite
Okay, thanks.  It's too bad you can't unlink/extract the pattern.  I'll add that in as a feature request.  I did try breaking the line then deleting the segment I didn't want, that worked.  You'd think trim would work also.
Message 4 of 13
michallach81
Mark has right it's because of pattern. You need to remove pattern constraint, just hoover over pattern icon, click it when it will turn bluish and hit delete key. Now you will be able to trim them. Same is true for projected (intersecting) lines, to trim you need first break the link. In general if lines is something more then a line it carry some additional information you have to remove that reference.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 5 of 13
HughesTooling
I think the only work around would be to use points, make a pattern with points then use a coincident constraint between the points in the pattern and lines that are not part of the pattern. If you think about it the whole point of a pattern is all the items are the same.
Mark
Mark Hughes
Message 6 of 13
michallach81
Pattern is parametric in sketches, you can re-edit by double clicking on it icon. This is only reason why it can't be trimmed. Remove constraint, that's all.
To illustrate:trimm.gif
Michał Lach
Designer
co-author
Message 7 of 13
SGoldthwaite
That worked, thanks!
Message 8 of 13
....What is a Pattern Icon ??  That would be good to tell people.
Message 9 of 13
michallach81
Michał Lach
Designer
co-author
Message 10 of 13
chrisplyler
It's the only icon that doesn't exist right before you create the pattern, but does exist right after you create the pattern.
Message 11 of 13
I don't see the symbol your showing.
Message 12 of 13
chrisplyler
Edit the sketch.
Also, constrain your sketch elements.
Message 13 of 13
Ya know, I wish I could get the flow of Fusion 360 but I can't.  I've spent hours and days watching Youtube and the training courses on the AutoDesk website.  I seem to be wasting too much time.  The program seems full of inconsistencies and incongruities ".. do this, but don't do that unless the three planets align", align, that's cryptic too.
I'm ok with AutoCad and super comfortable with Visio but I can't wrap my head around the way this was programmed.  I'd love to be able to create my ideas on a powerful forum in the 3D world that was more user friendly.  This is not it.
Thanks for your input.
