Help with Joints
Help with Joints
jeffescott
Advisor Advisor
Help with Joints
jeffescott
Pls see attached file. I drew the sketches so that the parts are all where they are supposed to be.
I can ground the base.
I can create a rigid joint between the bttm slider (teflon) and the base.
I can get one of the arms to move in and out.
But im totally baffled about how i can get the cam to move correctly.
By pulling the cam forward the arm should slide on the angled ramp to move outwards.
Been trying for most of the day to get it to work.......After this  works i need to build a lever assembly to move the cam.....but that is for later.
TrippyLighting
Slider joints and motion links between them!
The model is attached.
jeffescott
Thats the ticket thank you very much.
