Help with Impact Simulation - Hammer Impact
Hi everyone, I have a seemingly simple problem but don't know how to go about it. I need to simulate and find the deformation due to a hammer impact on a simple L shape as shown (dimensions 50x50x10mm):
Top end face is constrained while a force is applied to bottom face as shown. The only information I have as of now is that the hammer force or impact load is 50 kg. How would I go about this:
a. Linear static analysis with F = 500 N applied as shown above?
b. Event Simulation where Transient Force = 500 N with an assumed ramp up and ramp down time of 2 milliseconds?
c. Some other method to simulate an impact load or impulse force that I'm missing?
mohammed.aliTDPXK
Hello @Anonymous ,
I would recommend to go with Event Simulation.
--> You can model a hammer head and include in the simulation and provide initial angular velocity.
--> Or use impact load condition for transient load. Time 0 will have 500N magnitude(0,500 and .02, 500 for example)
Let me know if this helps, Do like the post and accept as solution if this answers your query.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
tonySWCR2
Impact simulation is not a simple thing. Materials do very interesting things at high speed and load and the simulation has to take this into account, you need a good material model with more than just a static stress/strain curve.
A hammer blow is not a static problem so static simulation isn't going to give you very realistic results.
I would also be careful when specifying the hammer blow as a force value. Is that peak force and over what time period is the impact? You probably don't know this information, so setting the correct masses/inertias of both parts by ensuring the material models are correct and then giving them the initial velocity of the impact is the right thing to do. If you have a constant force that is applied you can add that too, but most of the effect of a hammer is from its stored energy (kinetic) not the force being applied to it during the impact.
Explicit analysis is what I would use for this problem. I am not sure on the solver that Fusion uses but judging by the inputs "Event Simulation" is the one you want, as it asks for a small time window so it is probably using an explicit solver.
mohammed.aliTDPXK
Hello @tonySWCR2 ,
Yes you are right, event simulation uses explicit solver and I have suggested the same.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
