Help with getting Text to work.
AllanRidesBikes
Message 1 of 14
AllanRidesBikes
I haven't used the Text tool in a while but it worked great then.
Today I go to add text to a model and it's different. Cool. But when I make a text box, there is no option to actually create text like on the video
You can see in the pic below that I have created a text box but then that's it. Nada.
What am I missing/doing wrong here?
Allan
Accepted solutions (3)
Replies (13)
Message 2 of 14
jhackney1972
There have been some reports that the text dialog box does not show up after selecting the text box points.  I think, cannot find the article, that this has been mostly reported by users operating on a MAC.  Is this your case.  One solution I read about was to sketch a line and use the second command to place text on a path, then you can suppress the path sketch.
John Hackney, Retired
Message 3 of 14
AllanRidesBikes
I'm on a PC.
Odd, I just was able to successfully make a text box on one plane but not the one I need to make one on.
Funny thing is that it ALWAYS worked before. 😕
Message 4 of 14
jhackney1972
Can you attach your model so I can take a look?
Message 5 of 14
AllanRidesBikes
It's attached.
I was able to add text along a path but...
Message 6 of 14
jhackney1972
Why are your doing it Begrudgingly?  What did I do?
Message 7 of 14
jhackney1972
Please indicate the plane you want to place text on, but could not.
Message 8 of 14
AllanRidesBikes
Sorry, I deleted that.
By accident all I saw was your top line in your signature ("If you find my answer solved your question, please select the Accept Solution icon") and was thinking, "That's not a solution" haha!
My apologies.
Message 9 of 14
AllanRidesBikes
The plane that says "Garage Door Freespace" is the plane that I was trying to use a text box.
Message 10 of 14
jhackney1972
Thanks for explaining, I understand your reasoning.  It is odd that the Text command, using two point text box works for me.  I am also on Windows 10 with a rather old PC.
Message 11 of 14
AllanRidesBikes
Well, thank you for trying. I restarted Fusion (as a last ditch effort) and I get the same thing. 😕
Message 12 of 14
jerry_mallett
Community Visitor
Community Visitor
Not helpful!  I searched for "How to Add Text"  can't seem to find an option to add text
Message 13 of 14
jhackney1972
Not helpful in what way?  You did not attach your model or fully explain what you need.  I took a guess and create a short video to show the use of the Text Command.
Message 14 of 14
TheCADWhisperer
@jerry_mallett
Are you in an active sketch?
Fusion Help | Create text in a sketch | Autodesk
