Help with gear
Help with gear
Stanislavkt
Help with gear
Stanislavkt
Hello
Brother gave me this part for 3d print.
First of all i want to ask, how would you create this part?
I´ve tried myself, but i got stuck at one point. Since i dont know any module and all i know is a number of teeth, im trying to do this with only with calipers and protractor.
I hopefully did the larger gear right with the Add-in i downloaded.
What im trying to achieve is to have all six rectangles 6 milimeters away from each other, since thats what i measured.
Also, can i somehow snap it to the circle , so they dont overlap each other?
Would it be better if i imported a picture of the gear into fusion, or is it just a waste of time?
Hopefully you can understand what im trying to do.
Thanks for all the help
g-andresen
1. watch some tutorials
2. try out Plugins e.g this
günther
HughesTooling
@Stanislavkt wrote:
Hello
You can calculate the module by divide the diameter by the number of teeth + 2.
Here's an example of a 24 tooth gear with 2 module. 52mm OD divided by 26 gives the 2 Module.
Mark Hughes
Owner, Hughes Tooling
etfrench
What is the outside diameter of the gear? How many teeth (I know I could count them from the image 🙂 )?  What is the diameter of the bore?
ETFrench
