Help with Fusion 360 Basics Tutorial
Message 1 of 19
I'm trying to learn 360. I bought the Fusion 360 Basic Tutorial by Autodesk. On page 22 and 23, I follow the directions. I have all the lines drawn according to the pictures. My drawing is 0.6 above the X axis. When I get to #17 on page 23 and select Diameter Dimension and put in 1.2, my drawing jumps to 1.2 above the X axis and my drawing on my screen isn't the same as the picture in the book. The 1.2 dimension isn't 0.6 above and below the X axis. What am I doing wrong?
Replies (18)
Message 2 of 19
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
Message 3 of 19
I don't see your solution to my problem. Thanks for replying to me.
Message 4 of 19
TheCADWhisperer
Attach your file here.
Do you understand that simple request? Yes or no.
Message 5 of 19
Bear with me. I guess I don't understand your simple request. OK, you want my file. How do I send you my file? I see the attachment button below. Where is my file in Fusion 360 to send you? When I'm in 360, I don't know how to copy the file and attach it here.
Message 6 of 19
TheCADWhisperer
I am using Windows version of Fusion, not sure how this compares to Mac version.
File ManagementFile Management
Click on the glyph shown and then select Export and select *.f3d  (this is the native file format for Fusion files).
Pay attention (you can control) to the location where your file is being Exported.
Reply here and click on Attach paperclip and then browse to the location where the file was exported.
Message 7 of 19
Let's see if I got it.
Message 8 of 19
TheCADWhisperer
The file that you attached is empty?  I do not see any geometry?
Can you post a screen capture of what you see?
Message 9 of 19
I'm 73 years old and this is getting rather overwhelming. I just took a screen shot and can't find it on my computer. I'm running Windows 10 and it says it's in One Drive. Now do I have to set up another program that will frustrate me even more? I'm going to take a break from bothering you until I can figure out whether I even want to continue with 360. If I read the Autodesk Fusion 360 Basics Tutorial Book and follow the instructions in the book and it doesn't work on my computer, what's the point of even trying? I can open the file I just sent you, in Fusion 360 on my computer and it runs for me, why doesn't it run for you. Maybe I'm just an old dog that can't learn new tricks!
Message 10 of 19
TheCADWhisperer
@Anonymous wrote:
I'm 73 years old and this is getting rather overwhelming.... Maybe I'm just an old dog that can't learn new tricks!
Well, I am 62.  Does that mean I have <11  functional years left?  😮
Message 11 of 19
I'm back and guess I'm a glutton for punishment. If you're 62, you probably understand the frustration of a baby boomer like me. Let's start with getting on the same page. Do you have the Autodesk Fusion 360 Basics Tutorial book? If so, I'm stuck with Tutorial 2 on page 20. Let's try another attachment. I've drawn what's in the book and saved what I was working on up to instruction 16. Instruction 17 (where you put in Diameter Dimension) is where I'm having the problem. When you put in what they tell you (1.2 into the value box), my job jumps up from 0.6 above the X axis to 1.2 above the X axis. Can't figure out what I'm doing wrong. My saved project is named Second Job.
Message 12 of 19
TheCADWhisperer
Right click and select Diameter Dimension.
When in doubt - right click everything.
Video to follow when it is done compiling.
Turn on your sound...
Message 13 of 19
Thank you for getting me over my first stumbling block. Now to move on to the next one.
Dave
Message 14 of 19
chrisplyler
Forgive me if I'm wrong here, but it sounds like you haven't been working on computers almost every day for thirty years like some of us have. There are, of course, going to be a multitude of things that seem trivial and obvious to those of us who have, which are going to be new and perhaps confusing to you.
But don't be discouraged. It just takes time. I'm not specifically talking about the Fusion 360 software, although it takes time also. I'm talking about everything.
For example, it's pretty common that a software program has a File menu. It's typically somewhere in the upper left corner of the program's window. This menu will usually contain the basic file management task that are applicable to the program, such as Open, Save, Print, Export, and other stuff like that. Not all programs adhere to this convention, but most do, if it's applicable anyway.
I will suggest that you not only attempt the tutorials, but also just take fifteen minutes to click on every menu, and just read every option available. Expand every menu and hover your cursor over each item contained therein to see a "tool tip" pop up with a description of what each one does. Explore the menus down at the bottom/center of the window to see what's controlled down there by those icons.
I apologize if I've aimed too low in my suggestion. Perhaps you've already got a feel for everything. But I thought it might help.
Message 15 of 19
Thank you. You aimed low, because that is where I'm at with Fusion 360. I appreciate all the help I can get. And I know what you're talking about. In your video tutorial above, you clicked on "edit sketch". I saw where it was on your screen, it wasn't there on my screen. After clicking around on stuff, I found it and it worked just like you showed me.
Message 16 of 19
chrisplyler
Well, I'm glad to have helped in some tiny way. But I wasn't the one who posted the video above. That was @TheCADWhisperer . You can see each respondent's forum name at the top of his post.
Message 17 of 19
Another stumbling block. I'm learning to create a cylinder. 1.2 in diameter and 4.0 in long. Called Third Job. I'm trying to cut a rectangular groove to accept a woodruff key. Made the cylinder, installed the 3 lines as per directions. Right line 0.221, bottom line 0.441 and left line 0.211 as in the tutorial book. When I click on the Coincident button on Constraints and the two end points at the edge of the circle, I get "Failed to Solve". What am I doing wrong? Hopefully the file will attach to this e-mail.
Message 18 of 19
TheCADWhisperer
Blank file.
I recommend that you run free Autodesk Screencast Recorder to show how you are exporting and then Attaching these files.
Message 19 of 19
TheCADWhisperer
@Anonymous wrote:
1. ... cut a rectangular groove ....installed the 3 lines as per directions.
2. Hopefully the file will attach to this e-mail.
1. A rectangle is 4 lines.  You might need to hit P on the keyboard and Project the fourth line from the edge of the model.
2. You cannot use Email to Attach files here - you must use the web browser forum Reply.
Note that you can always use the built in Windows Snipping tool to show exactly what you see on your screen as I have done above image (and the image from my screen in Post #6).
>>Click Here<<
