Help with design for battery pole hole in lid
carmelo_cruz
Message 1 of 22
carmelo_cruz
Hi everyone.
I am new to fusion 360 and CAD. I have completed a parametric box with lid and need help designing a hole for the battery pole. Attached is the picture of the object that I need the hole for. It is a mix of a circle and two flat sides. The circle measures 32.004mm and the distance between the 2 flat sides is 28mm.
Any guidance will be appreciated.
Accepted solutions (3)
Replies (21)
Message 2 of 22
davebYYPCU
Circle with rectangle attached to it, set dimensions.
Might help....
Message 3 of 22
mufuo
I made something like the attached one, you can make changes from it. Don't forget to check out what kind of work I do on Design History.
Mustafa Furkan Özel
Project - R&D Manager
LinkedIn
Message 4 of 22
carmelo_cruz
Hi mufuo.
That is a really great design and I really appreciate it. But what I need is the hole for that for a box lid.
See the attached .f3d with the lid design.
Message 5 of 22
carmelo_cruz
Can you explain how to do this? I am new to this. In another reply, I have attached my lid design.
Message 6 of 22
TheCADWhisperer
How are you measuring a plastic part to 3 decimal places?  What measuring instrument are you using?
In any case,
you should always Attach the *.f3d file of your attempt here (see the Attached file of my attempt).
Message 7 of 22
TheCADWhisperer
Edit: I now see that you have Attached your lid file...
Where are the dimensions for your Sketch8 in the file that you Attached.
If I drag the geometry it goes anywhere?
Since  you are new to Fusion - would you like to learn how to do this correctly step-by-step?
Message 8 of 22
carmelo_cruz
All the dimensions are in parameters. Yes. I am loving being able to design my own parts and want to learn as much as I can.
These are the parameters used:
Message 9 of 22
laughingcreek
@jeff_strater - when you open the first sketch in the design posted above by the OP, the lines show as all black, and there is a fully constrained symbol on the sketch.  if you try to drag something you can see it clearly is not fully constrained. any thoughts on why?
Message 10 of 22
TheCADWhisperer
... want to learn as much as I can.
@carmelo_cruz
Start a new part file.
Create your named Parameters.
Create a Center Point Rectangle as shown below...
It is usually best to make use of existing symmetry about the Origin.
This will pay dividends later on...
Attach your new file here for next set of steps.
Message 11 of 22
carmelo_cruz
Thanks.
Here is my basic lid template with the extrusions. The two extrusions are the ones that I need to learn how to apply the correct format.
Sketch 2 has the lid.
Sketch 3 has the circles
Message 12 of 22
TheCADWhisperer
I do not recall posting any instruction steps about creating any Extrusions?
My method is to progress one step at a time and I have not given next set of steps?
You will never see any undefined blue geometry in my sketches.
Message 13 of 22
carmelo_cruz
sorry about that
Message 14 of 22
carmelo_cruz
@TheCADWhisperer I think I did it!!! I followed the sketch from your file in order to create the one on my lid and then negative extruded the profiles. See the new file.
Message 15 of 22
TheCADWhisperer
@carmelo_cruz
Fully define your sketches.
Blue lines and white dots should keep you awake at night.
Examine the Attached file...
Edit:  See if you can figure out how to edit to change the flats on the hole to the other sides.
And the correct width...
(and position)
Message 16 of 22
will.astill
I definitely agree that you should have fully defined sketches.
Not doing so can create so much pain somewhere down the line and it's good to get into the right habits.
This would even apply to construction geometry.
Message 17 of 22
davebYYPCU
Those pics are from native Fusion app?
Or an add in?
Arr, you have removed them now.
Message 18 of 22
will.astill
Sorry, thought I'd removed the pics.
I posted a reply to agree and added a few screenshots before I realised the post was in the Fusion forum.
My screenshots are from Inventor. Just ignore them.
Message 19 of 22
davebYYPCU
They went to the black hole…..
Message 20 of 22
will.astill
Feeling bad so I looked up how to show DoF in Fusion.
This post looks quite useful tho..
https://forums.autodesk.com/t5/fusion-360-design-validate/sketch-degrees-of-freedom/td-p/6803824
