Help with a Part Design
xaltoth
Observer Observer
xaltoth
Observer
Observer
Hi, Im a new user to Fusion 360, and i was trying to figure out how to create a part in the program. I went through the tutorials and the PDF and couldnt figure out how to make it.
The best way i can describe it is. In the image the back of the part is flat vertically, the sides are 45 degree angles meeting the front which is also a 45 degree angle.
Edit: I also included the design i was able to quickly mock up in Maya, as that is what I use professionaly.
martin.zatecka
please look at the attached video. It is about the sketch and extrude. The sketch define basic shape of part and the extrude add the volume.
You can work with the design for example remove some volume, again create a sketch and remove the profile from body... or you can use some predefined features of "modify" toolbar.
Please let me know if you need more details.
regards
Martin
Martin Zatecka
UX Designer
