Help with a drawing
Help with a drawing
mygadgets3d
Help with a drawing
mygadgets3d
Will it be possible to draw this object in Fusion 360?
TrippyLighting
Yes!
harry.doldersum
You might want to be a bit more specific with your question?
I can't see any reason why this couldn't be modelled in Fusion. I guess, it just depends on how you'd want to execute it.
TheCADWhisperer
@mygadgets3d
Can you File>Export your *.f3d file of what you have attempted so far to your local drive and then Attach it here to a Reply?
Warmingup1953
Certainly!... Will you plasma cut 3mm Steel sheet and roll it to create the "Basket"?
etfrench
3d print, laser, water jet, plasma, 5 axis mill?
ETFrench
