HELP ! - using thread features between two component not matching ,,
halimidris91
halimidris91
Thread.PNG how to fix this ? need help on this thread.. I.I'm gonna 3d Print it .. but from my view the thread not matching between two component..
I had select M8x 1.25for both using Thread Tools..
mavigogun
Check out this video- addresses more topical issues than just thread alignment.
etfrench
I haven't watched the video yet, but one way to create perfectly matched threads is to:
  1. Join the bodies.
  2. Create the threaded holes.
  3. Split the bodies.
Another:
  1. Create a tube with an inside diameter for the threads and an outside diameter larger than the threads.
  2. Thread the hole.
  3. Position the tube in the two bodies/components.
  4. Split the tube.
  5. Join each end to its respective component.
You'll also need to add chamfers.
ETFrench
halimidris91
For the bodies.
It's 2 components already.
Is there a way to join the component together ?
Thank you for another.. will work on that .
  1. Join the bodies.
Another:
  2. Thread the hole.
  4. Split the tube.
halimidris91
thank you for sharing this vids. I have go through this, but its a little complicated because the video itself is 30 min..
