Help Understanding Component Timeline Relationships
chrisqx2
Message 1 of 9
chrisqx2
Been using Fusion as a hobbyist user for years and thought I was quite proficient, until I encountered this small detail regarding component editing which I cannot seem to find an answer for, so my first post.
All components are children of the assembly. None are linked.
Problem: I noticed interference between components A & B.
Rolled back Component A's timeline to edit the offending sketch, and Component B ceased to exist.
I understand that all components timelines are contiguous under the assembly timeline, thus rolling back component A's timeline brought me to a point in time before component B's was even created.
My question is, how does one edit Component A without losing Component B, which is a necessary reference to resolve the interference issue.
This seems so basic, and I'm disappointed I don't know or cant figure out the answer.
Replies (8)
Message 2 of 9
g-andresen
please share a sample file
günther
Message 3 of 9
chrisqx2
As the file name implies, this is an oversimplified example. My question: is there a way to edit the sketch of Component A while using Component B (body, sketch, etc) for reference, projections, etc.
Hope that makes sense.
Message 4 of 9
TheCADWhisperer
See Attached.
(I removed existing parent/child history dependency and then dragged order in Timeline.)
Message 5 of 9
chrisqx2
Thank you for taking the time to demonstrate. I understand the strategy, but cannot figure out how to remove the child / parent dependency to allow the timeline features to be re arranged at the assembly level.
I went through all the component contextual menu's, properties, etc and couldn't see an obvious function.
Where is this done?
Chris
Message 6 of 9
TheCADWhisperer
@chrisqx2 wrote:
... but cannot figure out how to remove the child / parent dependency to allow the timeline features to be re arranged at the assembly level.
@chrisqx2
Are you referring to your attached "Oversimplified Example", or are you referring to your real model?
Message 7 of 9
chrisqx2
I was referring to your comment "I removed existing parent/child history dependency and then dragged order in Timeline."
I was asking how the parent / child dependency of a Component is edited or deleted. I've never seen an option to perform this function. Often, in error, I've created a component nested under another component and figured there was no means to re-define an alternate parent, so always deleted and created a new component.
I appreciate your time, very helpful. While I consider myself quite proficient with the software, its the basic housekeeping intricacies / limitations that I need to study a bit more.
Message 8 of 9
TheCADWhisperer
I am not at my Fusion machine at the moment, but Purple lines are Projected lines.
A projected line is a child and has a parent.
The child cannot exist in time before the parent.
You second component had a purple child line - I deleted it with the Delete key on my keyboard.
Now I could drag the second sketch and extrude before the first sketch and extrude.
Of course this was a very simple example.  The process is usually more complex on real parts and requires a strong understanding of parent/child relationships.  If you use the BORN Technique as much as possible and practical you largely avoid these dependencies.
Message 9 of 9
chrisqx2
Ok, now I understand, and that makes complete sense.
I was fixating on a menu function for some reason.
Thanks again.
