Help!!!!! Sketch geometry not updating
Message 1 of 15
I want to increase the diameter of the small circular holes. But when I edit the sketch, it doesnt update the geometry
Replies (14)
Message 2 of 15
g-andresen
please share the file.
File > Export > save as f3d on local device > attach to next post
günther
Message 3 of 15
I basically cant modify any sketch and get it to update the geometry
Message 4 of 15
TheCADWhisperer
Who turned off the History?
You?
Should have gotten a warning...
Can you Undo back to where there was still a history on the Timeline?
Can you Open an earlier version?
Message 5 of 15
I can turn it back on
But the problem was say I increase the diameter of the hole cut out, it only increased the sketch not the actual hole
Message 6 of 15
TheCADWhisperer
@Anonymous wrote:
I can turn it back on ...
Not - turn it back on - get back to a state before it was turned off.
Otherwise you might as well do this part over (fortunately it is a simple part).
Edit: I started to remodel the part for you - and noticed that some of your dimensions do not make logical sense?
Message 7 of 15
How do I turn it on  again?
Message 8 of 15
Does it look turned on?
Message 9 of 15
TheCADWhisperer
When did you turn it off?
If you turned it off in this session of Fusion, then click Undo until it comes back with list of sketches and features on the Timeline.
If you turned it off in earlier session of Fusion, then open an earlier version of the file from the Data Panel.
Message 10 of 15
TheCADWhisperer
You shouldn't have to ask this question.
The answer is - sort of (technically yes now) - but it doesn't matter as at some point it was turned off and all history destroyed.
Message 11 of 15
I have opened a previous version. Where do I turn it on?
Please I wanna apologise in advance if it seems like a dumb question but I am new to fusion 360. I used solidworks for 5 years. It is very different to fusion
Message 12 of 15
TheCADWhisperer
If the features are not on your Timeline in earlier version - you will have to start over.
Actually Fusion is the same as SolidWorks in this respect (feature history vs base solid).
When you remodel this from scratch - you will want to make sure each sketch element is fully defined - no blue geometry - just like in SolidWorks...
Use the BORN Technique and Fusion will be just like in SolidWorks.
Message 13 of 15
Okay but the problem now is
How do I solve this particular problem? It might be a setting on the software that I am using
Message 14 of 15
TheCADWhisperer
Make sure that you are capturing design history.
There are two ways...
Set in your Preferences to always capture design history
or
right click at the top of the browser...
If at any time you are tempted to turn this off - STOP - and ask questions first.
Message 15 of 15
I really and truly appreciate. You are a  genius.
Yes, that solved my problem. I should have that turned on at all times, that way I can edit the sketch and it updates the geometry.
Again thank you.
