HI @Anonymous,
One thing I notice that when you are selecting your options when using Project to Surace is that you choose your current sketch plane (I believe) as your Face and you never chose any curves to project. Assuming you are trying to project the inserted SVG onto the box body what you would want to do is select the face of the box as the Face and the SVG as your Curves. Then project it along a vector and the OK button should be selectable then. One thing to note is depending on how you created your sketches you may need to create a new one for the projection, but I am unsure from the video, its just something to note. This screencast below shows my steps on projecting to a surface - hope it helps!
Hopefully this helped answer your question. If so, please feel free to mark this solution as an answer, that way others can benefit from this thread as well. If you need any more help or would like more clarification, please don't hesitate to let me know. I'm more than happy to help!
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
