help on alignment / joint
johnptc314159
1,175 次查看
17 条回复
1 条消息(共 18 条)
johnptc314159
i cannot see a simple way ( eg like inventor constraints ) to
1. align the tube bottom with support bottom
2. bring the two faces together
3. align the two angled faces
then make a rigid joint ( easy)
thanks john
0 个赞
1,176 次查看
17 条回复
回复 (17)
2 条消息(共 18 条)
g-andresen
Hi John,
Please share the design and show how the edges and faces to be joined.
günther
0 个赞
3 条消息(共 18 条)
johnptc314159
There should be a pdf… currently I cant post a fusion file to the forum ☹
Thanks for your patience
0 个赞
4 条消息(共 18 条)
wmhazzard
Under modify, use the align command and then use an as built joint.
5 条消息(共 18 条)
johnptc314159
once i do one pair of  faces and try the second one the parts move out of alignment from the first align 😞  Am i missing something  ??
thanks
0 个赞
6 条消息(共 18 条)
johnptc314159
here is a zip of the fusion file
7 条消息(共 18 条)
lichtzeichenanlage
What is the bottom part in your design?
8 条消息(共 18 条)
johnptc314159
see post #6 for parts file
the support plate bottom piece is flat
the tube bottom is flat with radius on the corners
0 个赞
9 条消息(共 18 条)
laughingcreek
assembly files are a pita for folks trying to help out.  can you unlink and post a straight .f3d file instead?
10 条消息(共 18 条)
johnptc314159
Will try
0 个赞
11 条消息(共 18 条)
johnptc314159
i zipped them here  thanks.  now called    .f3z  ??
0 个赞
12 条消息(共 18 条)
laughingcreek
they are still .f3z files.  so it is an assembly file that references other linked files.  that means we have to download multiple files to our machine, and then uploaded back up to our fusion account before we can open it.  then we have to make sure we delete the project.  if you attach a model with no linked components, (an .f3d file), we don't even have to save it to our harddrive.  we can just open it.
13 条消息(共 18 条)
johnptc314159
i will look, in export that wasnt a choice only f3z :[, let me go further up the line and retry 🙂
0 个赞
14 条消息(共 18 条)
lichtzeichenanlage
You have to break the links for that.
15 条消息(共 18 条)
johnptc314159
ok  understood..........  better late than never. files attached.
john
0 个赞
16 条消息(共 18 条)
laughingcreek
So for some reason you attached 2 seperate files.  still had to save them to my account.  I made the body in one of the model's a component, and then inserted the other model with the other body as a component, and unlinked it.  At this point the model is in the state I was suggestion you up load the model as.
So I'm guessing from this (just a guess) that you don't know how to use components yet.  You can put components together with joints.  here is a screen cast showing how to do it with your file. (I didn't know exactly where, but you should be able to figure things out with this.
FYI-the suggestion to use align to put the components together, and then use an as-built joint is crap.  You use as-built joints when components have been modeled in their correct position from the start.  the work flow using align and then an as-built joint will cause you nothing but grief down the road.  not a good modeling practice in fusion.
also attached is your file with the joint.  you;ll note in the screen cast that I temporally allowed a position capture so the components would remain where they were during the joint operation, but once I was done I delete the position capture.  it's a good idea to not collect those in your timeline.
https://knowledge.autodesk.com/community/screencast/242479c6-67ce-4871-a349-f4b25ddc74dc
17 条消息(共 18 条)
johnptc314159
need a little more help.  please see pdf in post 1.
it shows the almost position needed.   the bottoms flush, facing faces touching and angle faces in line....
i could not figure out how to 'joint' this together 😞
i havent used components a lot as i most do single piece cad to cam to cnc stock removal 🙂
many thanks for your input
0 个赞
18 条消息(共 18 条)
johnptc314159
here it is in f3d   shows almost final position BUT ITS NOT JOINTED 😞
0 个赞
