Help modeling threads
rhetteshleman
rhetteshleman
Hello, I'm trying to model the threads on this tumbler lid. I've found lid specs at 90mm x .5. I think I'm pretty close but I'd like to get closer.
The closest thread type I've found is ISO Metric profile. The 90 is correct but there isn't a x5 profile. I also think I don't need to model the entire length but when I uncheck that setting it throws it off. Any ideas how to get the model more accurate? Thank you
Drewpan
There are a few ways to create a thread without using the actual thread tools. One way would be to simply create
a coil on the surface. It wouldn't be a great thread but would do what you want.
 Cheers
Andrew
MRWakefield
I've created a custom thread file (see attached). Hope you find it useful. Let me know if you need anything altering etc.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
rhetteshleman
Thank you, I'm not sure what to do with this file. Import into Fusion?
MRWakefield
You need to copy this to a special Fusion folder. You'll find official instructions here.
Unfortunately next time Fusion is updated your custom thread files become 'orphaned' and left behind as the thread folder is changed. However, there's an add-in called ThreadKeeper which manages this and moves all your custom threads to the new folder when Fusion receives an update.
Hope this helps.
ps I'm off to bed now as it's getting late here in the UK. If you have any questions I'll try to answer them in the morning.
Marcus Wakefield
