Help Joining bodies to make 1 smooth corner between peices
Hi there,
Im pretty new to fusion 360, im trying to work out how to join these two bodies together at the angles to make a simple smooth corner. i haven't been able to wrap my head around it but wanted to ask for advice.
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
sure! heres the file below. i may have done this entire step incorrectly but its concept for something
KristianLaholm
I removed a lot of the small things you did at the end of the timeline and removed everything creating the "left" part.
Press/Pull on the face that would overlap to get some clearance.
Mirrored the part (to get 2 identical parts)
Loft (sold) with G2 Curvature
well dang , thank you so much! did you press pull from the top or from the sides, do you think you can show the process with one of the video timeline things?
(edited because i didnt realise a word was blocked.)
KristianLaholm
You can see the steps in the timeline in my file, I think it calls Press/Pull "OffsetFace" in the timeline.
I did the press/pull on the long "vertical" face to avoid intersecting bodies, it would be better to do it in a sketch.
Loft doesn't work if the faces are to close (the loft will fold ove **** self)
Ayy! I wish i knew this way earlier thank you so much 🙂
