Help in fixing round sharp hat on tank track
buder18
Message 1 of 9
buder18
Hi first post here 😄
i am not sure in what category i have to put this
i need some help to fix/make that  sharp rounded hat on the guiding teeth of my tank track
i have no idea how you call this operation so i can'T find help
but i tried  a sweep  it kind of wanted to work but then go all over the place
Thanks for taking the time to help me
  • Help
Replies (8)
Message 2 of 9
JHRendon
Could you share a picture of your model, the figure you want to make, or the 3D model file?
Message 3 of 9
buder18
i did but seem it didn't upload lets retry
Message 4 of 9
JHRendon
Ok, create another arc.
and use loft. profiles woul be the two arcs and the rail the arc on the middle. Maybe you make a sketch in the solid part and make the arc. I used a surface,  you can creat another surface to complete the part or make a mirror, use stitch and combine the solids.
Message 5 of 9
buder18
thx another question following this how do i turn the purple line into a sketch line ?
or (how to turn any edge into line without simple projection?)
i mean by that when i create a new sketch on any bodies there no real line and sometime make thing unselectable like now
i can't select the edge
Message 6 of 9
JHRendon
You could break the link of that projection. (right click)
then line will change of color and you can edit it
Message 7 of 9
davebYYPCU
Purple lines are sketch lines.
You will need Project tools in Fusion working without them makes life difficult.
Project on reference and other auto project tools are in the Preferences.
Solid Tools need blue shaded profiles,
Surface tools work with curves.
Might help....
Message 8 of 9
buder18
Thanks alot  took me a while to understand i need a cross line  for the 2 arc  lol
nice and shiny
Message 9 of 9
JHRendon
Coool! If you have more questions, I'll be here.  You can also send private messages if you need more help. đŸ‘œđŸ––
