HELP! Fusion just keeps spinning and never loads a design after a relaunch
Hi --
I have an odd problem and I hope I can describe it well:
I run Fusion 360 on two machines -- a Windows 7 desktop (1) and a Windows 10 laptop (2)
I created a design, called "meyou" on (1) and saved it and everything was fine. I was using the latest fusion version when I designed it.
I started work on (2) and clicked on "meyou" and got some notice that I must relaunch fusion to use the design. I think that might have been because fusion had updated on (2) not long ago but I was not working with "meyou".
So, I relaunched fusion on (2) but all it does is keep spinning on the "meyou" design and it does not load it. Keep in mind that I do NOT click the design -- it just tries to load once it starts.
Now, I had the brilliant idea of using machine (1) and saving the design as a different name ("me-you-dish") and then I could delete "meyou" and machine (2) would not try to load it over and over. I could save "me-you-dish", BUT I still cannot delete "meyou" because fusion says the design in is use, so I'm stuck with it.
This wouldn't bother me EXCEPT that on machine (2), every time I start fusion, the spinning never stops, and it chews up 40% of my CPU.
Can someone do something to say that the design is not it use or something?
Betty
