- Mute
- Permalink
- Report
Ok, this has been bothering me for sometime and I thought I might bring it to the attention of others and see if they are being held back by this.
Attached is a pic of the before and after from the fillet and you will notice that the fillet function does not retain the length of the contacted extrusion. It extends the extrusion I have created, but only in parts where it needs to. This causes me some grief when I have to then design the part which this is located in. Just to explain a little further, I work with a 3mm recess in the adjoining part, but I will have 2mm+ which extends past this recess. Not a nice look in my opinion and unfortunately for me no real work around.
Now as for a solution, I am completely stuck
- A revolve of a circle/arc will not work since it comes in contact with different surfaces and therefore the tangency is different. This eliminates this as a possible solution.
- leave it without a radius and play around with fillets options on the CAM side of things. I am yet to try this, it is something that just crossed my mind. This is where I need people with more experience on the CAM side of things to chime in (I know it isn't the right part of the forum)
Ideally, what I would like to see if a consistent radius fillet which is tangent with all the surfaces it comes in contact with, without modifying any existing features and therefore reduce the likelihood of chatter during roughing or finishing if I was to add no fillet.
Happy to share as many screen shots as possible, but I can not share the file.
Ariel
Any thoughts or ideas would be much appreciated.
