Message 1 of 15
I need to make a 180 degree bend with a 10mm radius in 5mm Ti.
Then I need to bend this arc around a cylinder 10 mm radius.
Not sure how to proceed at all
The double bent arc needs to go on the square end of the drawing component spring:1 sketch 1
