Help adding a texture
csbrads
csbrads
I am trying to add a pineapple like cross hatch texture to the top portion of the attached file.  I have watched the you tube videos but cannot figure it out.  Can someone help please? I am adding a picture of final part needs to look like, it does not have to be exact.  If you can point me in the right direction I would appreciate it.
I have been using fusion for about a week now just can't figure this out.
laughingcreek
a possible approach.
you'll not I turned the time line on.  I also repositioned the sketch to the origin to take advantage of the origin planes.  the revolve line wasn't perpendicular to the model axis, so i fixed that also.
csbrads
Wow, this looks fantastic!  Thank for the help.  I will review the timeline to see if I can now create it myself.
Thanks again, I have been trying to do this for days, lol and was getting frustrated.  I see now it's always better to ask for help.
csbrads
This looks great, I have one question, is it possible to cut the pipe into the body so that the diamond shapes appear to be raised instead of the pipes.  I tried to do the cut command on the pipe but received 4errors?
Thank you
csbrads
Apologies, after I sliced the model it looks like it is cut into the body
csbrads
Just wanted to say thanks to laughing creek for helping me with the texture on my part.  I printed it and I think it turned out nice.pineapple finial.jpg
jhackney1972
If you feel @laughingcreek gave you a good solution, please go to his post, the one that gave you the solution, and mark it "Accept Solution".  This will thank him for his effort, take the post off the active board and allow others to find the solution to a similar problem.
John Hackney, Retired
