Having trouble with Fusion web
gabe_develZYUNB
gabe_develZYUNB
Community Visitor
Community Visitor
I'm a student who got access to Fusion web recently. Up until now, everything was sunshine and rainbows. Now? It's buggy, doesn't render my whole object (as seen in the image, only rendering the tools, browser, etc) which means I can't do anything to it. It's just so broken. I'm very disappointed, especially since I've been meaning to learn Fusion for a long time now (as a both a hobby and potentially a skill usable in my future), and also work on a passion project as well. I'm not sure if anyone can help me out, because this is probably a very niche thing that isn't very well maintained, but that's fine. If you could, please give me advice!
dsouzasujay
Hi @gabe_develZYUNB ,
Thanks for reporting this, and sorry you're having trouble with the Fusion Home tab.
From your description, it looks like the Home tab is loading, but the model itself is not rendering correctly.
Could you please try the following and let us know the results?
  1. Open the design directly in the Fusion Design workspace
    From the Home tab, try opening the affected design in Fusion. Does the model display correctly once it is opened in the Design workspace?
  2. Try another design
    Please check a different Fusion design from the Home tab. We'd like to know whether the rendering issue affects all designs or only this particular model.
  3. Restart Fusion
    Completely close Fusion, restart it, and check the Home tab again.
  4. Collect Diagnostic Log Files
    If the issue continues, please go to:
    Help > Support and Diagnostics > Diagnostic Log Files
    and attach the generated ZIP file to this thread.
Could you also share a short screen recording showing the issue from the Home tab through opening the affected design?
If the problem occurs only with this particular design, please share the Fusion dataset with us.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
