Having a trouble with shoe sole
I am new to Autodesk Fusion 360. I want to make custom shoes and now I cannot apply the sole that I have scanned with 3D Scanner with the shoe model I made. Now sole of the shoe is flat. Does anyone have any idea what should I do?ModelModel2018-03-07_23-23-11.jpg2018-03-07_23-23-22.jpgI want sole of the shoe look like thisI want sole of the shoe look like this
aaronkcap
Thicken the tspline to add some dimension to it then you should try the joint command between the two bodies.
Thank you for your advice @aaronkcap. I just finished my shoe yesterday, but I did not finish them in Fusion 360. Here is my solution. I got an advice from my teacher.He recommended me to use Geomagic wrap for making insole and this is what I got.
I import my shoe into Solidwork then make it closed by using extrude and surface cut.
Then I import my insole from Geomagic wrap into Solidwork and use surface cut again. Thicken and Fillet edges.
rgonzalezgrza
I know this was YEARS ago and a longshot, but did you by any chance record the process of how you did it? Im doing a very similar project and have this exact issue
