Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Has lofting been affected with the last update?
4 REPLIES 4
541 Views, 4 Replies
I've done numerous lofts like this until the last update.
...STREAKER IV DOUBLERS... is the last one that I did that worked.(file attached)
...SHURIKEN STREAK DOUBLERS...won't work now.(file attached)
...I'm still pretty new at Fusion 360, could be my brain quit! Anything is possible!
Thanks for looking
Greg Rodney
Southridge CNC
4 REPLIES 4
I am having loft issues as well.
I had a loft issue after the latest update but after I restarted the system it did not happen again.
HughesTooling
You have a problem with your rail, because you have points you've used to make your spline I think your rail is constrained to a point rather than the spline. In the screencast I delete the points then use intersect to make a point I know is on the spline. I still get an error after fixing the rail because it would make a self intersecting surface. You can get a surface if you extrude surfaces and use the ends in the loft. File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
in reply to: HughesTooling
Thanks for the solution Mark.
I really do appreciate it.
Greg
