harmonic resonance of the structure or resonate frequency of the structure
eric_strebel
eric_strebel
I am looking for a way to calculate the harmonic resonance of the structure or resonate frequency of the structure...
Is there a way to do that in Fusion? or any other application....
I have designed a ribbon microphone in fusion and had it printed in metal on shapeways. Turned out very nice. We had it tested, but it needs some adjusting to ring at a different frequency. We could change things and reprint, but at $320 a pop thats not really an option for us. If we can get close to our ideal resonance then we can reprint. If there is a way to select different materials and test for the harmonics of that material and for the existing shape that would be ideal.
Thanks in advance of course. Here is a picture of the printed ribbon microphone.
TrippyLighting
@I Eric, just tagging someone here that might be able to help @Anonymous
This is one Bada$$ looking mike!
Thanks for the tag @TrippyLighting
Eric...I have a course specifically on this topic and some free spots open...just use the link below.
https://www.udemy.com/fusion-360-simulations-modal-frequencies-analysis/?couponCode=RELEASEPARTY1Q18
This covers the theory and math behind a modal analysis and resonance while also walking through the specific steps for the simulation. If you have any questions afterward just let me know!
As a side note, typically a modal analysis and harmonic analysis are 2 separate things. The modal analysis just finds frequencies, whereas the harmonic will take into account damping to provide stress, deformation...etc values. Fusion 360 can do modal but not harmonic.
eric_strebel
Sorry for the delayed reply. Much appreciated. I guess I need to figure out exactly what I need here..I am working on that.
eric_strebel
@TrippyLighting thanks for getting the correct person. Much appreciated
@eric_strebel , feel free to ask any other questions as they come up. I know its a steep learning curve to get into simulations so we will help where possible.
What is your end goal?
