Hangboard Sheet Internal CAM kernel error
lukemaynes
lukemaynes
Attempting to CAM project, but keep getting the same internal cam kernel error. Was wondering the best way to diagnose an issue like this. Thanks!
jhackney1972
You  had a lost face reference in your second sketch in the Design Environment timeline.  Fixed that and the issue goes away.  Please look at the path settings to be sure they suit.  Model is attached.
John Hackney, Retired
lukemaynes
Okay after the face reference is corrected, I get a unrelated kernel error. It seems to occur when I am using multiple depths, as I unselect this the toolpath seems fine. Is there a way to circumvent the multiple depths option but still able to have "multiple depths" in the toolpath, if that makes any sense. Thanks again!
jhackney1972
Take a look at these two attachments.  One is working with the multiple depths issue and the other is the complete board using the Linear Pattern function on the three toolpaths.  I removed the "Stock to Leave" on all toolpaths so if you want to make finishing passes, you will need to add it back.  Please check the multiple depths I chose to see if they suit.
