Half circle torus
Half circle torus
jaxbuddie
Message 1 of 19
Half circle torus
jaxbuddie
I have a 10" x 0.5" torus, I only need Half of it, How does one cut half a circle away? Thanks for all who help.
Accepted solutions (3)
Replies (18)
Message 2 of 19
evanp4509U4JZ
If you created it at the origin just use the split body command and a perpendicular plane as the splitting tool. If it is remote of the origin use the center point  of the torus and construct an axis through that and then construct a plane at an angle on that axis. Use that plans as a splitting tool as described.
Message 3 of 19
jaxbuddie
I used the split body option, and not sure what to do after that.  Everything I do ends up not showing any difference, still a full circle. How do I select the perpendicular plane?
Message 4 of 19
jaxbuddie
Do I do as you suggested from the start, like delete what I have and redo? and do as you suggest at build time?
Message 5 of 19
jaxbuddie
jaxbuddie
Explorer jaxbuddie
in reply to: evanp4509U4JZ
7m ago
Message 6 of 19
jhackney1972
Video will show what @evanp4509U4JZ told you to do.
John Hackney, Retired
Message 7 of 19
jaxbuddie
Hi and thank you for your assistance.
I'm new kind of and not sure how long it takes to finish but it's been 7 min. and when I reload the tab is still tells me
This video is currently being processed. Please try again in a few minutes.
I've never watch a video like this but think it's probably great. so am I needing to wait longer to have it allow me to see video?
Message 8 of 19
jhackney1972
The time required depends on the Autodesk servers.  Be sure to Reload the page from time to time, it will show up.  I will monitor on my end and be sure it does develop. It is there now for you to watch.
Message 9 of 19
jaxbuddie
Wow, Thank you Mr. jhackney1972,
Fantastic.  You are my friend. lol. Great help.
Message 10 of 19
jaxbuddie
Now I have a hole to move it seems to not move the same way, can you assist me in moving a hole up a bit?
Message 11 of 19
jhackney1972
Do not understand the question.  Please attach your model for assistance.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
Message 12 of 19
jaxbuddie
Message 13 of 19
jhackney1972
You failed to attach your model, a pretty picture defines what you want to do, I need to model to possibly show you how.  Please see my instruction in my Previous post.
Message 14 of 19
jaxbuddie
Please don't be offended. lol. I am sending you just a piece of my file. but showing me how to move this hole will allow me to move any holes. Thank you.
Message 15 of 19
jhackney1972
The main thing to remember is to place the hole in the correct position in the first place.  In the video I demonstrate two basic methods of doing this.  I also show you how to move a hole but this is not recommended, place it using an established method and then simply change the location dimensions.
Message 16 of 19
jaxbuddie
Thank you, I'm still waiting for your last video to load, but wanted to say this, the hole I'm wanting moved was mounted in exactly the right place at the time I punched it but because you showed me how to remove half of my torus I moved the bracket up .255" so I could move the bottom bar up. lol. Thank you so much for your teachings. You are great at this.
Message 17 of 19
jaxbuddie
I just wanted to thank you for your help, you were great and a very good instructor. Thank you.
Message 18 of 19
jaxbuddie
I posted the other one of this same statement to myself but it was supposed to of gone to you.
Message 19 of 19
jhackney1972
You are welcome and thank you for the kind words. The Forum and I am available to try and answer any questions you may have so please post your questions as they come up.
