>SHEET attribute not displaying page number in Fusion 360 Electronics Schematic
ftcgn-mph
Observer Observer
ftcgn-mph
Observer
Observer
I’m using Autodesk Fusion and encountering the following issue:
In my Schematic drawing, the page number does not display and instead shows the text >SHEET. All other attributes, such as >DRAWING_NAME and >LAST_DATE_TIME, display correctly. Even the >SHEETS attribute, which shows the total number of sheets, works as expected.
I also tried entering the text directly in the Schematic. The >SHEETS attribute still displays the number correctly:
but >SHEET continues to display the literal text:
This seems to rule out a library issue, so I conclude that the software is not converting >SHEET into the page number.
I attempted to create a custom attribute named SHEET, but it reports that this attribute is reserved.
How can I make the >SHEET attribute display the current page number in my schematic, similar to other system attributes such as >DRAWING_NAME, >LAST_DATE_TIME, and >SHEETS?
Thank you in advance for your support!
jorge_garcia
Hello @ftcgn-mph ,
I hope you're doing well. This is currently a known issue and we are working on fixing it for a future release. I've added this thread to the existing ticket and the fix should be forthcoming shortly.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
ftcgn-mph
Observer
Observer
Thank you. It's good to know.
Best Regards,
Minh P. Huynh
rmessing-gpd
I'm also seeing this issue.  Good to see its a known issue and is getting fixed shortly
