I've been watching a lot of fusion videos on YouTube.
Learning about other work flows in fusion, and one question I have is the benefit or lack there of between grounding components vs joints.
My understanding and process when designing is to ground my components upon creation.
And only use joints for those component that need some sort of mobility or active state.
But I've seen some only grounding the base component and then everything else using joints.
For example when I design a large exterior sign, I simply ground the components because in the end all I'm after are the flat patterned sheet metal parts for me to cnc.
Please correct me if I'm wrong here, but for what I need from my designs doesn't really require joints?
If so what's the benefit?
