Grounding Linked Component
ndprsha1
ndprsha1
Hey is there a way to ground a component that is still linked?  I tried and couldn't get that option to show in the pop up menu.
TrippyLighting
Yes, right-click on the component and then select "Ground"
If that component is not a component but an assembly of components, however, you'll have to select one of the components in that assembly to ground the assembly (assuming the assembly itself is joined properly).
