Green lines what do they mean?
jeffescott
Advisor Advisor
jeffescott
When I change the shape of an extrusion.  The downstream operations have green lines where the old projections were, so clearer they represent the previous location.
I can and do delete these green lines to make a clean  sketch.
My question why are they there, and how to I get rid of them easier, then click and delete.
jhackney1972
Would it be possible to attach a model that shows these green lines?
John Hackney, Retired
jeffescott
Of course sorry
Please see component whisperer machine:1
Sketch Slot
Turn off body flat arm 1
jhackney1972
When sketch entities are show in the Light Green color it means that a "Fix" sketch constraint has been applied to them.  I have no idea how they were created, the method you describe does not cause it for me.  Most all of the sketch entities are "Projected" so they are fixed anyway by their relationship to the body or component that they were projected from.
jeffescott
Hmm I haven't used a fixed constraint in weeks.  Is it possible that the fold unfold process cause the "fixation"'.
So erasing them is a good idea? think so because a don't want to end up with a whole bunch as I play with the profiles, can't see why removing them harms anything.
Thanks for the info anyway.
