Okay, just yesterday, I impulse bought a Razer Blade Stealth 13.3" laptop (2018 Model RZ09-0239 with Core i7-8550U and 16GB RAM). I had been using Fusion 360 on an old MacBook Air (A1466, 8GB RAM).
Here's the specs link for the Razer:
https://www.razerzone.com/Gaming-System/Razer-Blade-Stealth-H2-H3/p/RZ09-01964E31-R3U1Okay, on the surface, the key differences are obvious: a Windows laptop versus a Mac laptop, both with Core i7 CPUs (but different generations with the Razer having a new 8th-gen quad-core processor). The MacBook Air has "Intel HD 5000" (1536MB) integrated graphics whilst the Razer has Intel® UHD Graphics 620. Even though neither machine has a discrete GPU, I expected the brand new machine to outperform a base model Mac from the 2013/2014 era. But here's my out-of-box, post-setup experience:
* The Razer has extreme tearing in the Fusion 360 window -- even with a blank document. Just moving the empty window around the screen results in the interface bits trailing behind the main window - there's an annoying delay (All OS and software bits are current, including firmware). The Macbook Air doesn't have any display issues like this -- I'm trying to diagnose it now.
* POWER (PLUGGED IN): This tearing is directly related to whether or not the laptop is plugged into A/C power. The graphics are improved [of course] on A/C -- this is not a problem with the MacBook Air. Not at all. Of course, I want to operate it without A/C frequently, so this is a deal-breaker.
* I thought the newer integrated graphics model would work for my simplistic models (nothing I do is complex) and didn't give it a thought. The age difference (and price difference!) in the two machines is large. I expected better from such similar hardware.
* I also shopped for other machines in this range, but they all seem to have the same integrated graphics (620) unless you splurge for a laptop with a discrete GPU. Razer has a GTX 1060 in the more-expensive and larger laptop.
* This laptop has (for some reason) a 4K display with touch. It's a really nice display that I have no issue with (but not great to read in my sunlit kitchen). If you turn the resolution down, the aspect ratio for the screen limits the usability of Fusion 360 at lower resolutions, making it a "why bother" scenario. I suspect the extra real estate is causing some serious perf issues in general but I haven't done a variety of testing.
* Both machines have different generations of Core i7, but both are rated similar clock speeds: 1.7/1.8 Ghz base speed and a much higher burst "turbo" speed (3.3 Ghz for MacBook Air and 4.0 for the Razer). I'm suspecting that Fusion 360 doesn't kick the CPU into burst mode -- at least not with an empty document open, so it's just running at the base 1.8
* Obviously, the old MacBook Air doesn't have a discrete GPU either, but Fusion 360 seems perfectly fine on it for simple models.
TAKEAWAY: While the Razer is good in general and seems like solid hardware and build quality (this 4K touchscreen is awesome), I'm going to return it and get a new machine with a discrete GPU -- so 15" MacBook Pro it is. Apple has the best trackpads on the market anyway, and I'm just done messing around. (Also debating returning it and going up to the Razer Blade 14" with GTX 1060.) Either way, if you can get a GPU, get a GPU.
