Ghost sketch elements
Message 1 of 11
I have had this happen a few times to me where there are sketch elements, then i delete some of them, but they dont dissapear - and can longer be selected.
A video from fusion 360 staff showing another feature exhibits the same problem at 6:11 (he tries to delete the "R" a second time and is unable to. As well there are some ghosted elements on the left top side of the sketch)
https://youtu.be/G3Xt1Es_dg8
Replies (10)
Message 2 of 11
roambotics_scott
This is not very helpful but deleting things just generally seems to be a recipe for disaster.
Hopefully this can get converted to a bug report by someone.
Message 3 of 11
Someone was experiencing something similar, and said logging out of Fusion then logging back into their account fixed it.  Something to try.
Jesse
Message 4 of 11
Deleting things from a sketch is very common and should be supported. In my work, I cannot imagine a way to design and sketch many of my models without deleting curves and lines. Is everyone else really so good at sketching that they don't delete?
Message 5 of 11
Hi Jason, I've never myself had any trouble deleting sketch elements.  If you run into an issue like that I'd be interested in taking a look at it, and hopefully coming to some conclusions, by you sharing the model file, such as by exporting it as a .f3d file and uploading it to this thread.
Jesse
Message 6 of 11
roambotics_scott
I delete stuff all the time - even when I know exactly where going, maybe I want to make something that is half ellipse and half circle, then I'm breaking lines and deleting. It's definitely necessary core functionality - but given the current state of the system, you just kinda have to hold your nose and expect things not to work consistently or reliably.
To expect otherwise is apparently deemed «negativity».
Message 7 of 11
Jason, usually there is a fairly straightforward way to do exactly what one wants, but a willingness to try and learn is necessary, and hmm, I would call it an expectancy of success, NOT an expectancy of failure, or negative outcome.
Jesse
Message 8 of 11
roambotics_scott
Oh come now - trying something reasonable [deleting something in a sketch] and then having it not work isn't «expecting failure or a negative outcome».
It's trying something perfectly reasonable and then having it not work.
I'm sure there is a work around - which is great for the short term - but it's also a pretty big bug that should be fixed.
Message 9 of 11
Let's hold our horses until more is known about this sketch problem 😉  I suspect it must surface in limited use cases like imported SVG files or what not.  We'll see, if someone can provide a reproduction of the behavior.
Jesse
Message 10 of 11
The problem isn't not being able to delete sketch elements, they delete fine, but they stay around as ghosts visually. You can't select them, when you extrude they don't show, but visually the ghosts of them reman. They even remain in the left hand side cloud panel's previews. I have also never imported an SVG so it's not that. I'll see if I can make it happen in a screencast.
Message 11 of 11
That ghosting sounds like a different problem than Jason was describing.  Check out the image on this thread and see if it looks similar:
http://forums.autodesk.com/t5/design-and-documentation/body-doesn-t-move-with-sketch/td-p/5808208/pa...
From that it sounds like @TOwens777 found logging out and back in fixed his problems.
Jesse
