Getting a New Hole to Align with an Existing Hole ( with 2 separate components)...
catgrad
Message 1 of 11
catgrad
Hi all. I am very new to Fusion 360 and am trying to understand how to get two holes in two different components to perfectly align or snap so one is directly on top of the other.
Specifically, I have a new Countersink/Simple/Flat hole that I am creating in "Component A" that I need to align perfectly (or snap to/above) an existing Simple/Tapped/Flat hole in "Component B".
The assembly is a steel table where the tabletop ("Component A") is directly above the steel frame ("Component B").
Creating a new hole and selecting all specifications, Extents, and types is easy. It is getting the new hole to vertically align perfectly over the existing hole in Component B directly below that I cannot figure out how to do.
Any suggestions?
CH
Accepted solutions (4)
Replies (10)
Message 2 of 11
shahriarsifat1802164
While trying to perform the alignment things you can go modify >> align and select the faces,
Thank you.
Or, you can use assembly and select those faces of different components and make them align and rigid.
Thank you
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 3 of 11
TheCADWhisperer
Message 4 of 11
catgrad
Thanks for these suggestions, but my problem is that I cannot have either component relocate or move along with the new hole. Both "Component A" and "Component B" need to stay put. It is solely the new Countersink hole that I need to move/align with the existing threaded hole...not the entire component that the new hole resides in.
CH
Message 5 of 11
HughesTooling
Create a sketch on the face where you want the new hole, project the edge of the hole from the other component. On the hole dialog select the from sketch option and select the point.
Mark Hughes
Owner, Hughes Tooling
Message 6 of 11
etfrench
I usually use the same sketch to create both holes.
ETFrench
Message 7 of 11
HughesTooling
Trouble is in the example in my picture above the original sketch is on the other side of the body and I need counter boars on the other side to the sketch. Would be nice if the hole feature had the same options as extrude for example, where you can set the start plane. I quite often need counter boars both sides of plates and the same set of holes through several components bodies and could get away with one master sketch but end up with one or two sketches for each component.
Mark
Mark Hughes
Message 8 of 11
catgrad
Yes. Doing it this way (as I've learned the hard way) seems to make the most sense. The real run-in is when you don't initially know if/where you need a hole or not at the time you sketch the component/body.
Thanks!
CH
Message 9 of 11
g-andresen
If you would give an example of what @TheCADWhisperer  has already said, we could understand better what your situation is and give more specific advice.
günther
Message 10 of 11
catgrad
So I figured out what I was trying to accomplish. I've listed them in sequential steps. If someone want's to review and let me know if this makes sense or if there's a more efficient way to create a new hole in one component body and then move it so it snaps to/aligns to an existing hole in a different but adjacent component body, please let me know. Thanks to everyone for their input!
*With the entire Assembly activated:
1.) Create the desired hole (Countersink/Simple/Flat) in "Component A"...the tabletop.
2.) Select 2 Faces: The conical countersink face, and the bore's face...or simply select them once you've clicked on Move/Copy.
3.) Right-Click and select the Move/Copy command. If not done in Step-2, then select the two faces of the Countersink Hole.
4.) For "Move Type", select "Point-to-Point".
5.) For "Origin Point", select center white dot of the bottom face of the new hole's bore (holding down the CTRL key if on a Windows machine to keep snap points and mouse from jumping around).
6.) Hide "Component A" temporarily so you can better access the top face of the existing hole in "Component B", the table's frame.
7.) For "Target Point", select the white + or dot at the top face of the existing hole's bore.
8.) Click "OK".
Using the "Move/Copy" function of the Right-Click menu should have been more intuitive to me since what I was trying to do was "move" a feature like a hole. I was just making it out to be or thinking it was harder than it actually was.
shahriarsifat1802164, your suggestion mentioning to select multiple faces is what clued me in.
Surprisingly, there isn't anything this basic but straightforward that addresses moving or relocating and aligning holes anywhere that I could find....including on YouTube.
I wish that the Autodesk Screencast Recorder would format correctly on my HD monitor so I could capture the above steps in a screencast recording. Thanks to everyone who responded.
R/
C.
CH
Message 11 of 11
etfrench
It would probably be better to use dimensions and constraints in the sketch to position the hole(s).  User parameters can make this even easier.
ETFrench
