Get compute error when creating flat pattern in sheet metal
All it tells me is to check the body and bend patterns. Being a newbie at this, it doesn't tell me anything about the real cause. Can anyone let me know where I went wrong? I have attached the Fusion 360 project file.
HughesTooling
The trouble is the 2 end flanges touch and Fusion's modeling kernel automatically combines touching surfaces. In the attached I just changed the end flanges to adjacent. If what I've done is no good you could extrude the end faces a small amount before the flange is added.
Here's the problem, notice the face is combined.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Here's the file modified using extrude to give a 0.001" gap.
Mark
Mark Hughes
Thanks, I'll take a look later today.
TheCADWhisperer
@Anonymous wrote:
.... Being a newbie at this...
First thing I noticed is that your Sketch1 does not show as fully defined.
I would have recommended that you stop there and ask questions.
(My Sketch1 would have been 3 very simple rectangles.)
To make it easy to work - my overall length rectangle would have been relatively short until the geometry completed and then edited to full length.
