geometry on intersection of the plane and solid body
Message 1 of 11
Is it any way to create geometry (lines, arcs ... ) as a result of intersection of the plane and existing body so I can use it in a sketch?
I am trying to use split face or body but I do not want to affect existing body.
Marek
Replies (10)
Message 2 of 11
I_Forge_KC
When you create a sketch on the plane, just use the PROJECT > INTERSECT command to get whatever is sliced by the plane.
K. Cornett
Generative Design Consultant / Trainer
Message 3 of 11
I have just tried  as you said, but now I have a hard time to select just created contour to create for example extrusion.
Message 4 of 11
SaeedHamza
Could you share a screenshot of what you're having?
Saeed Hamza
Message 5 of 11
I have model of the part from customer and I am trying to modify it to stock size so I can use it in CAM for simulation.
Any other ideas on how to create a stock model for part like that? I have attached entire file.
Marek
Message 6 of 11
etfrench
What area needs to be modified?  Do you have the other half of the model?
If you're just changing the diameter or shape of a flange, then
  • Create the new geometry in the sketch.
  • Use the Split tool to isolate the change area from the main body.
  • Use the Revolve tool to create a new body with the changes.
  • Join the new body to the main body and Remove the old body.
ETFrench
Message 7 of 11
Basically, I have to fill in all the holes and add additionally about .02 per side. The other halve is just hidden, just turn off  Analysis sections
Message 8 of 11
etfrench
I would create a small cylinder that will fill one of holes completely. Use a sketch on the face to create the cylinder.
Create a pattern using the small cylinder to create bodies at each hole position.
Use Combine|Join to fill the holes.
 Once the holes are filled you could try the Press/Pull command or the Revolve command to increase the diameter of a flange.  If the entire body needs to be enlarged, then the Shell command may work.
ETFrench
Message 9 of 11
arashWA
Community Visitor
Community Visitor
Thank you, but how can I get this intersecton while Im in sketch doing 2d ?
Message 10 of 11
etfrench
The projected body needs to be earlier in the Timeline in order to project to a sketch.  If it is not, you can project to a new sketch then move that sketch earlier in the Timeline.
ETFrench
Message 11 of 11
davebYYPCU
Project > Intersect, has an option for selecting a body.
Your sketch has a lot of holes in the outline, so would be better to set options to Body, select the body then hide the body.
should have. Sketch, with a few blue shed regions.
Use Divide and conquer to fix that sketch.
Might help….
