Hi @Anonymous -
Thanks for reaching out on this topic. These are going to be a very hard questions to answer with 100% certainty. Let me explain.
In general, during the generative design process, structural analysis calculations are being run based on the loads, constraints and objectives you have defined. So the results are generally as accurate as your setup. If your inputs are wrong or an inaccurate reflection of reality, then design may not meed the desired performance conditions. I would say that the same general rules of thumb that apply to finite element analysis are appropriate when considering generative design.
Another thing to consider is the potential failure modes your design might see once in use. For example, if you are designing a bracket to carry a certain load, generative design can design for that purpose. However, if this bracket is mounted on a vibrating machine, and resonance conditions could be a concern, today, generative design cannot design for specific vibration requirements. This would require the proper vibration simulations to be conducted downstream, once an outcome has been downloaded.
I would always recommend a follow up set of simulations to test the outcome against all of the required performance tests to ensure the outcome is fully validated for all , not just structural as part of the generative design.
Mike Smell - Product Manager, Fusion 360 - Generative Design and Simulation
