Generative design error
cvf40
cvf40
I am trying to obtain a generative design model of a bicycle frame, but the study doesn't create any solutions cause i get this error message:
The preserve geometry and forces are the following:
And this is a section of all the geometries:
I upload the file in case anyone can help me,
Kind regards,
Carlos
karol.suchon
Hello, to solve the issue go to the study settings and move the mesh size to the tight region.
That will allows you to get the results.
But I will also look into the loads, probably you are applying too high a force becouse the first shape has a safety factor above the limit.
BTW if you have that high volume of obstacle volumes, draw a initial shapes, it is always easier for the software to mesh it later.
BR
Karol
