Generating gcode without the arc definition
My CNC is controlled with a piece of software called "Planet CNC" - it wasn't free.
I get all kinds of errors generated from my Fusion 360 gcode, the most curious of which is something about arc radius being wrong or something (I can't copy and paste errors because Windows).
So, my heart sank when I found the software developer's response to this thread at the Planet-cnc forum:
Yes, our software does not support these g-codes arc definition, you should use/choose different postprocessor.
Is there any way to convert the gcode to not use these arc definitions?
you can just email cam.posts@autodesk.com and they will do a custom post for you . They did a post for me that does what you need for a different controller.
tony
