Gear meshing in model
alphatozeta
alphatozeta
I have two gears attached to two shafts in bearing blocks that have revolute joints. Each gears' teeth are "engauged" with the other gears' position wish but when you rotate either gear the other does not move. How to you get them to move when the other one moves?
Thanks...Tom
HughesTooling
You need to use motion links, here's the link to the help.
I've attached a file with 3 gears as an example.
Mark
Mark Hughes
Owner, Hughes Tooling
