GE bracket tutorial - unfinished?
Message 1 of 8
Anybody tried GE bracket generative design tutorial (https://f360ap.autodesk.com/courses/ge-bracket-tutorial)?
It seems unfinished - just assigning geometry types and applying constraints, but - creating final body is missing.
Or I have missed something?
Replies (7)
Message 2 of 8
TheCADWhisperer
File>Export and then Attach your *.f3d file here so that someone can check your progress.
It takes some time for the Generative Design to run.
Message 3 of 8
TheCADWhisperer
What do you see when you click Explore?
Message 5 of 8
here it is:
Message 6 of 8
Dialog box "There are no outcomes to view in Explore yet. Would you like to generate outcomes now?"
After I click Yes button, a Generate window appears saying there is an error in the study (Status column=Error, with Repair link).
After I click Repair link Cannot generate dialog box saying:
Error: Incomplete setup: Missing structural loads other than gravity in load case "Load Case1".
Click here to select 'Structural Loads'.
Warning: The Milling 'Head Diameter' is large comparing to the model size. Review the Milling settings, model size and units.
Warning: Material 'Aluminum AlSi10Mg' is not supported for: Milling. The manufacturing cost will not be estimated.
Message 7 of 8
https://f360ap.autodesk.com/courses/understanding-generative-design/lessons/explore-outcomes
Yes, I can find whole the process here, but tutorial at the link  in my initial post is not complete.
Message 8 of 8
TheCADWhisperer
I don't see Activity 3 completed in the file that you Attached?
You should have 4 Load Cases shown in your browser.
