Garden Hose Threads
Garden Hose Threads
jevans3XST6
Message 1 of 20
Garden Hose Threads
jevans3XST6
I would like to model both male and female garden hose threads in Fusion 360.  Does anyone know what specs to use in the Thread dialogue box?
Many thanks - Jerry
Replies (19)
Message 2 of 20
etfrench
Post #9 in this thread has the specs.
ETFrench
Message 3 of 20
jevans3XST6
Hi etfrench,
Thank you so much for your reply.  I have seen that post previously and understand the specs; however, cannot find settings in Fusion 360 > Create > Thread (see image attached) that will reproduce these specs, i.e., what is the Tread Type, Size, Designation, Class that will give me the result required.
I am new to Fusion so perhaps I am niave in thinking that this is how I would create a garden hose thread.
Any further thoughts you might have would be greatly appreciated.
Cheers,
Jerry
Message 4 of 20
etfrench
This Fusion Quick Tip video shows how to do custom threads.
ETFrench
Message 5 of 20
jevans3XST6
Very helpful video.  I believe it will help me achieve the result I'm looking for.  Thanks so much for taking time to provide guidance.  Cheers!
Message 6 of 20
evaneaston
FWIW, I'm putting this here for anyone else looking.  I chased down the specs.   The NFPA 1963 spec (Standard for Fire Hose Connections, 2014 Edition) says:
A.1.1.
Some fire-fighting organizations use small hose less than 3⁄4 in. (19 mm) nominal diameter fitted with garden hose couplings. Such couplings should have 0.75-11.5 NH (garden hose thread) threads conforming to ANSI/ASME B1.20.7, Standard on Hose Coupling Screw Threads.
I found the ANSI/ASME B1.20.7 spec document from 1993 here and it gave me dimensions that let me produce the 3/4"-11.5 threads using the following National Hose Threads.xml file to put in my AppData\Local\Autodesk\webdeploy\production\<XXX>\Fusion\Server\Fusion\Configuration\ThreadData directory:
<?xml version="1.0" encoding="UTF-8"?>
<ThreadType>
  <Name>NH Straight Threads</Name>
  <CustomName>NT Straight Threads</CustomName>
  <Unit>in</Unit>
  <Angle>60</Angle>
  <SortOrder>5</SortOrder>
  <ThreadSize>75
    <Size>0.75</Size>
    <Designation>
      <ThreadDesignation>0.75 11.5NH</ThreadDesignation>
      <CTD>0.75 11.5NH</CTD>
      <TPI>11.5</TPI>
      <Thread>
        <Gender>external</Gender>
        <Class>2B</Class>
        <MajorDia>1.0625</MajorDia>
        <PitchDia>1.006</PitchDia>
        <MinorDia>0.9495</MinorDia>
      </Thread>
      <Thread>
        <Gender>internal</Gender>
        <Class>2B</Class>
        <MajorDia>1.0725</MajorDia>
        <PitchDia>1.016</PitchDia>
        <MinorDia>0.9595</MinorDia>
      </Thread>
    </Designation>
  </ThreadSize>
</ThreadType>
I've used the internal threads from this spec and had leak-free mating with standard US home-improvement store hoses using ASA printed with high infill.
Message 7 of 20
jevans3XST6
Hi Evan,
Thanks for chasing down the spec.
I have since tried using COIL to get a 3/4" thread, and through some trial and error, was able to get it to work nicely (see below); albeit the COIL approach produces sharp leading edges, which I don't know how to soften.
I suspect your solution will work much better and will try it.
Many thanks,
Jerry
Message 8 of 20
kmckinnonTXS3W
Observer
Observer
Old thread, I know.  I wish a garden hose wasn't so difficult to make for Fusion.  Every time Fusion updates, the folder to place the template changes.
https://www.thingiverse.com/thing:2920861
Can't you just add this permanently?
Message 9 of 20
stiller.design
Is that an NPT thread? there has been a year long discussion (and some promises LOL) to get this into Fusion. nudge 2
Message 10 of 20
hwimbrow
Community Visitor
Community Visitor
Thanks for sharing this - very helpful and worked great for my small project.
Message 11 of 20
addohm
Why not add internal threads as well?
Message 12 of 20
evaneaston
The xml file I provided above specifies both internal and external threads:
Message 13 of 20
jevans3XST6
Indeed, both would be helpful.
Message 14 of 20
bruromeo
Community Visitor
Community Visitor
Just copied the XML to a file, saved it and tried it out.  Using the other links in this thread I was able to find the current thread data directory.  This worked great!  I have a test piece I have been trying to get hose threads on, and I just modified the last thread test I had and used this custom thread.  Worked like a charm...
Bruce
Message 15 of 20
Natalia.Alcala
Community Visitor
Community Visitor
Hello, I am new to Autodesk how do I copy the .xml script to a file, so can then use it in Fusion 360?
Message 16 of 20
MRWakefield
Copy the attached xml file to the Fusion 360 threads folder. Unfortunately this is easier said than done as most times that F360 is updated this folder moves! An added problem is that when F360 updates in the future it's not kind enough to move your custom thread files for you. To make life easier I'd highly recommend using the 'ThreadKeeper' add-in, as this will manage all of that for you.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 17 of 20
getmtuned
Community Visitor
Community Visitor
Thank you, this saved the day for me.
Message 18 of 20
seika7
Thank you!
Message 19 of 20
adam_rou
Community Visitor
Community Visitor
The provided code was very helpful for my project. I needed to add the 1\2" for my particular project so here is an updated xml for those who would like 3/4" as well as 1/2".
<ThreadType>
  <Unit>in</Unit>
  <Angle>60</Angle>
  <!-- 1/2 inch NH Straight Thread -->
  <ThreadSize>50
    <Size>0.5</Size>
    <Designation>
      <ThreadDesignation>0.5 11.5NH</ThreadDesignation>
      <CTD>0.5 11.5NH</CTD>
      <TPI>11.5</TPI>
      <Thread>
        <Class>2B</Class>
        <MajorDia>0.8125</MajorDia>
        <PitchDia>0.758</PitchDia>
        <MinorDia>0.705</MinorDia>
      </Thread>
      <Thread>
        <Class>2B</Class>
        <MajorDia>0.8225</MajorDia>
        <PitchDia>0.768</PitchDia>
        <MinorDia>0.715</MinorDia>
      </Thread>
    </Designation>
  </ThreadSize>
  <!-- 3/4 inch NH Straight Thread -->
  <ThreadSize>75
    <Size>0.75</Size>
    <Designation>
      <TPI>11.5</TPI>
      <Thread>
        <Class>2B</Class>
      </Thread>
      <Thread>
        <Class>2B</Class>
      </Thread>
    </Designation>
  </ThreadSize>
</ThreadType>
(It appears in the list as  "NT Straight Threads")
Message 20 of 20
jevans2DXUA
Community Visitor
Community Visitor
Thank you!
