Fusion360
Fusion360
omereroglu170
Observer Observer
Fusion360
omereroglu170
Observer
Observer
Hello, it is truly the best company in the world. Thank you for everything. It is good that you exist Autodesk. But I have a question. Will I be able to run Fusion360 on a tablet or phone in the future? I do not always have my computer with me. What always crosses my mind is to be able to use it on a phone or tablet. What do you say about this idea? Do you have such a project? If you do, when will it be released? I am curious. Thank you for everything. It is good that you exist.
Drewpan
I think you can run fusion on an iPad now. You can certainly run a cut down version of AutoCAD on a tablet. You can
use a web based version of fusion also. The web based version should be able to be used on a tablet browser. I am
not sure how much functionality you would get on a phone because of the screen size but tablet should work.
Cheers
Andrew
HughesTooling
If you have a commercial license there is a browser version you can run now. Not sure if or how well it'll work on a pad\phone but worth a try.
Mark Hughes
Owner, Hughes Tooling
TrippyLighting
@HughesTooling I don't believe the browser version works on tablets like the iPad. It only works in Desktop browsers, but I will verify this through the Fusion Slack channel.
@Drewpan , there is no native Fusion version that runs on any iOS/iPad device. The newer Microsoft Surface tablet computers do run a full Windows OS, but that is an ARM, not Intel, version of the OS, and there is no native Windows/ARM version of Fusion.
If you've ever used shpr3D on an iPad, you'll see how far the Fusion UI would have to be changed to be a suitable and competitive alternative on a tablet device!
In 2017 I tried to use Fusion on a Microsoft Surface 3 notebook, using only the detachable screen and the Microsoft pen. It was a sobering experience!
Although I liked the screen itself and the performance of the device in general, the tablet experience, in combination with the dismal touchpad, was so bad that I sold the computer and bought a MacBook Pro. The trackpad on these devices, at least at that time, was so far ahead of any other computer that it completely defined the experience.
Using a tablet and pen is so different from using a computer, it requires significant changes to the UI. For example, how often do we use modifier keys or keyboard shortcuts when using Fusion on a "normal" computer?
There are no keys on a tablet!
