Fusion360 in Browser Crash
I'm using Chrome Version 60.0.3112.101
The session seems to crash every time I'm in a sketch, highlight a line, then hit the delete key.
Trying to turn a line into a construction line with 'x' doesn't seem to work. I have to select the line, then use the right click menu.
Is measuring not implemented yet?
Also, I can't back out of creating a sketch if I accidentally use a shortcut meant for sketch like 'l' 'c' or 'r'.
Still, I'm pretty stoked to see how much work is getting done on this! Keep it up!
Hi Georgio,
Thank you very much for your detailed feedback. This is very helpful for the team.
We have been able to reproduce the issues you have reported, and will be prioritizing delivery of fixes. As you note, you can still create construction geometry via the right click context menu. The instability on deletion of sketch entities will be a top priority.
Measuring tools have not yet been implemented, but they are high on our list of priorities.
Thanks again for your time, and for your excitement for Fusion 360 in a browser.
Jeff
