Fusion360 gear generator
Message 1 of 10
I see countless threads created requesting and asking about a gear generator. It seems like a very important feature and something much needed. I don't understand why it still has not been done!
Currently I have been using a vector gear illustrator and then importing them into fustion360, but the program is so bad at handling the svg files (even after simplifiying and reducing the number of vector points below 500) that the program either crashes or takes an insanely long time to load. I have 16gb RAM on my computer and no other program on my computer runs at such a lagging speeds.
WHEN are you going to implement the gear generator??
Replies (9)
Message 2 of 10
etfrench
Have you tried the spur gear add-in?
ETFrench
Message 3 of 10
adelemm
There are two other ways (besides import SVG files) to create a gear in Fusion:
1) To create a spurgear from Add-in dialog as following command: Menu > Scripts and Add-Ins > spurgear
2) The other way is to insert stardare parts from Macmaster: Toolbar > Insert McMaster-Carr Component
There will be some Design Accelerator toolsets as well been planned to be added in the near future, would it be possible for you to post this requirement to our IdeaStation? our PD and product management teams are frequently reviewing this to determine the priority of our planned features:)
Fusion 360 Quality Assurance
Message 4 of 10
Thank you I didn't know these other options existed. I cannot find a way to add a gear I found from McMASTER-CARR. When I find the product where is the CAD icon? Do all products have them?
Message 5 of 10
adelemm
Just record a quick video to show how to insert a part from McMaster. check it and let me know if you have more question:)
https://knowledge.autodesk.com/community/screencast/5cf731c8-f6ab-4633-b9c1-b95788ce1ad2
Adele
Message 6 of 10
daniel_lyall
@adelemm post your vid on the tips and trick section
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 10
adelemm
Message 8 of 10
DaveGadgeteer
The SpurGear add-in from Autodesk has the diametral pitch wrong, and it's very confusing to figure out how to compensate for that.
BetterSpurGear fixes that problem.
But of course we users reallllllllly want much more capable gear generation tools, like what it would take to generate gears for an automotive differential.
At least, helical and herringbone gears. And bevels at various angles. We can build these with thin spurs connected by lofting, but it's very tedious and error prone.
Message 9 of 10
PhilProcarioJr
What you guys really want is this tool for Fusion finished! Start yelling and maybe it will happen.
https://www.youtube.com/watch?v=eKdTTE4j8so&feature=youtube
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 10 of 10
daniel_lyall
it's back in the idea station
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/bolted-connection-for-fusion/idi-p/63...
Daniel Lyall
The Big Boss
Mach3 User
