Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fusion360 chamfer size
1 REPLY 1
JJackrabbit
483 Views, 1 Reply
Hi all,
I'm new to the world of CAD/CAM modeling but Fusion360 is the first serious software package I'm using.
And so far it's working great! And also did my first CNC work with Fusion.
But I have a question about a specific design.
I would like to chamfer a part i'm drawing at the moment like this:
How can this be accomplished with Fusion360?
So the chamfer starts wider and ends nearer to the end
[img]http://i.imgur.com/MFOddfq.png[/img]
1 REPLY 1
HughesTooling
in reply to: JJackrabbit
Unfortunately there is no variable chamfer option. There is a variable fillet, with a bit of effort and the use of the patch workspace you can make a fillet, delete the surface in the patch workspace and replace with a flat surface to achieve a variable chamfer.
I've done a screencast to demonstrate.
Mark
Mark Hughes
Owner, Hughes Tooling
