Fusion360 and Alias
Fusion360 and Alias
Fusion360 and Alias
Dear Autodesk Sir,
I just downloaded Fusion360 for one week. But my job requirement still need to achieve Class-A surface level.
Does Fusion 360 have  "BlendCurve" function to make curves for creating boundary for loft or other surface build tool ?
Or I can use Aciassuface to build my 3D with class-A surface, then through it into Fusion360 ?  The axis direction is different. Can you fix it for better integration ?
Best regards,
Roger
Mike.Grau
Hi @Anonymous,
Welcome to the Forum and thank you for posting your question.
I think you would like to work with T-spline in the sculpt environment.
The great benefit is that you will have your T-spline model and your parametric design in one tool.
Here is a link to our youtube channel which has great tutorials how to work with T-splines.
https://www.youtube.com/playlist?list=PLmA_xUT-8UlLfPIsxMZWGx50lQht4bJqh
You could import quad mesh files like an *.obj into Fusion 360 and convert it into T-splines as well.
I hope this helps.
