Fusion won't select anything useful
So I've wasted the obligatory 45 minutes trying to get Fusion to do something useful.
I'm just trying to select a curve. I want to select the edge of the 2nd curve down (the one in the middle of the hole) but Fusion has objected to this. The picture below is a 2 step hole through material. Since I started Fusion this morning, the only thing it will select is the opening at the top of the hole. Which is dumb, since there is no material there. I would think when you point to a material and click the mouse, Fusion would select the thing you're pointing at, not the invisible item that doesn't exist over the top of it.
Is there something similar to "select filters" in fusion like in Solidworks? (if you get those set wrong in SW it will refuse to select stuff). Because Fusion doesn't have any actual menus I can't peruse through them to check, and Fusion's help answered "LOL. Just Give Up." It's all tribal knowledge.
So as is usual, I will now put off the job I was going to do today and come back later in hopes Fusion is in a better mood. It is frustrating knowing I can never quote a customer job if it involves Fusion because there is no way to estimate the number of hours that will be wasted trying to tell the world's most advanced software in 2018 to drill a hole.
