Fusion Split Body Error - No Intersection
kratjk21
kratjk21
I have this part that is curved on both sides, I've extended one side and am trying to split body along the curve to cut the excess off that doesn't stick to the curve but am getting this error.
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
jeff_strater
my guess is that these areas are the problem.  But, as @g-andresen says, we need the model to find out more
Jeff Strater
Engineering Director
kratjk21
Here is the file
jeff_strater
thanks for the model, @kratjk21 - I was able to get this to work by first creating an Offset Surface (offset 0) of the splitting surface:
then, use the Untrim tool, I deleted the inner hole in the surface:
results in a nice surface:
and, that can be used to split the body.  Model attached
Jeff Strater
kratjk21
THank you so much you're an absolute legend. Cheers.
